  3. Tracing a net
  • Replies 13
  • Subscribers 137
  • Views 25258
Tracing a net
J Wilwert
J Wilwert over 16 years ago
I would like to trace a net through the layout heirarachy and then plot the traced net.  I have done this with a DIVA script, and would like to rewrite the script using assura.  Possible? I need a little help getting started as I am not well versed in using assura.  These traced net plots are very useful.   Many thanks in advance,
John Wilwert
  • J Wilwert
    Quek,
    Cool !!!!  All is good !!
    I've checked the .rsf file and it looks like everything is there that I need to automate this!
    Thanks for all your help,
    John Wilwert
  • Peter123
    Peter123 over 15 years ago
    Hi Quek,
    The assura syntax look similar to DIVA syntax..
    So, can i use DIVA instead of assura to perform the task mentioned?
     BTW, does skill executes "drcExtractRules" ?
    or in other word, can i execute DIVA in skill using drcExtractRules ?
    I'm currently executes DIVA in skill using ivDRC....
    Pls help...
    P
    See my post to your other question /forums/p/18159/1260347.aspx#1260347
