  3. Tracing a net
  • Replies 13
  • Subscribers 137
  • Views 25255
Tracing a net
J Wilwert
J Wilwert over 16 years ago
I would like to trace a net through the layout heirarachy and then plot the traced net.  I have done this with a DIVA script, and would like to rewrite the script using assura.  Possible? I need a little help getting started as I am not well versed in using assura.  These traced net plots are very useful.   Many thanks in advance,
John Wilwert
  • dmay
    dmay over 16 years ago
    If you are running Cadence 6.1.4 and the nets are not that big (not supply nets), then you can use Connectivity->Nets->Mark Net, and then use Connectivity->Nets->Save All Mark Nets  to save the results to a cell. You could then plot the new cell.
    Derek
  • J Wilwert
    Hi Derek,
    I'd really like to say that I'm using Cadence 6.x!  Well, that is not exactly true.  Do you have any ideas on making this work in Cadence <6.x? (5.1.x)  THANKS!
    John Wilwert
  • dmay
    Actually, we are still using 5.1.41.x and don't know when we'll be on 6.1.x. I just happen to know about that particular feature and knew it would be easier than a new ruledeck for Assura. We use a third party verification tool to extract our supply nets for separate viewing/plotting. Unfortunately, I can't help you with Assura.
    Derek
  • Quek
    Quek over 16 years ago
    Hi John
    Perhaps you can code something similar to:
    drcExtractRules(
       layerDefs( "df2"
          m1=layer("Metal1")
          m1Pins=textToPins("Metal1")
       ) ;layerDefs
       geomConnect(
          via( cont m1 poly psub ... )
          label( m1Pins m1 )
       ) ;geomConnect
       vddM1=geomGetNet(m1 "VDD")
       vddM2=geomGetNet(m2 "VDD")
       vddM8=geomGetNet(m8 "VDD")
    ) ;drcExtractRules
    Now open drc and set avParameters ?outputErrorLib to "Output Error Lib". In "View Additional Functions" secton of the drc form, please select "Create New Layout Database". In the outFile form, save lvs layer "vddM1" ... "vddM8" to the actual DFII layers. Now run drc. You will get a new library with the vdd net.
    Best regards
    Quek
  • J Wilwert
    Quek,
    Thanks for jumpimg in on this - I really appreciate the help.
    Everything looks good.  I am down to the part:
    How (and where) do I do this?  I am stopped cold on this part.  Any thoughts?
    Again, THANK YOU!
    John Wilwert
  • Quek
    Hi John
    Here are the steps:
    In the outFile form, please do the following:
    a. Fill in the name of a new library
    b. Enter a path for the new libary
    c. Enter the name of the tech library
    d. For "Assura layer name", enter the name of the layer that appears in the rules file
    e. For "Layer name", enter the name of the layer that appears in LSW
    f. Add the layer to the text box
    g. Repeat for all other layers
    Please see the sample below. : )
    Best regards
    Quek
  • J Wilwert
    Quek
    Thanks - So how do I get to this form?  Where can I find it?
    Also, I suspoect that this form writes or appends a file somewhere.   Maybe, I could just write or append the file.
    John Wilwert
  • Quek
    Hi John
    At the end of the lvs form, please enable "View Additional Function". Then enable "Create New Database" option and press the button.
    Best regards
    Quek
  • J Wilwert
    Quek,
    Thanks - I found the form and followed it through.
     I guess I need to back up a little and clearify a point.  The net I need to plot may be any net a designer chooses.  So it may ot may not have a pin on it.  In the past, I've just placed an "X" on the net using the TEXT.drawing layer.  It think this slightly changes the code above.  Could you help me  get this coding correct?  Sorry for this oversight.
    John Wilwert
  • Quek
    Hi John
    Please use this:
    layerDefs( "df2"
       myText=text("TEXT")
    geomConnect(
       label(myText m1)
    The above would create net labels instead of pin labels.
    Best regards
    Quek
