  3. Switching between simulations
  • Views 14400
mhgc
mhgc over 16 years ago
When I am running simulations with two separate testbenches using spectre through ADE within the same icfb session and annotating DC node voltages and operating points, it takes a very long time to draw the annotations when I switch to the other testbench.  The only solution is to open the ADE window first and select the results before opening the schematic with the annotations, but that gets very tedious. I'm running IC5.10.
 Anybody run into this problem and have a solution?
 Thanks.
  • Quek
    Quek over 16 years ago
    Hi mhgc
    It is not recommended to run multiple ade sessions within the same Virtuoso session because this is not an intended use model. Please use only 1 ade per Virtuoso session. The same issue has also been explained in COS solution 11108900.
    Best regards
    Quek
