  3. incomplete nets
  • Views 15640
incomplete nets
tester
tester over 16 years ago
Dear All,
I am using IC5.1.41 schematic, Virtuoso XL layout and Jazz CA 18 Design kits, and here is the problem:
During the layout XL, I tried connectivity->incomplete nets, there is a "vdd!" marked as an incomplete nets. In the layout windows, two pmos and two connection areas from the inductor and vdd are marked. When I tried to remove the pmos to different places and checked each layers of the inductor connections, I did not see any extra nets. Are there anything that I might have missed?
Tester
    Tester,
    Without having familiarity with that design kit, hard to know. The best thing would be to log a service request via http://support.cadence.com and then somebody can work through this with you.
