  3. how to activate/deactivate a component during a simulat...
  • Subscribers 133
  • Views 7191
how to activate/deactivate a component during a simulation
wighou
wighou over 15 years ago
Is it possible to activate/deactivate a component during a simulation ? This very usefull function doesn't seem to exist in the schematic editor.
Regards
    Add a string property on the instance called "nlAction" with the value "ignore". Or in IC61 onwards add a string property "nlIgnore" with the value "spectre" (the nlIgnore approach allows you to ignore the component in specific netlisters).
    There's also a GUI based approach using my solution http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11523164
    In addition there's an enhancement request to have such a GUI as a standard part of the tool.
    The other approach you can use is in the hierarchy editor to set the instance to "bind to open".
    Take your pick - lots of ways of doing this...
  • wighou
     Thank you Andrew.
  • ywguo
    ywguo over 14 years ago
     It looks a great idea to set a string property "nlIgnore" on some instances. However, it does not work in my design. I try to set the value to "spectre" and "ams". Both fails. I search the schematic L editor User guide (for IC 6.1.3). But not any information about nlIgnore except nlAction. Probably it is not updated because you said that nlIgnore is a new property from IC 61 onwards. How do I find that related document? Thanks very much.
     My tools version is IC 6.1.4.500.
     Best Regards,
    Yawei
    Yawei,
    You presumably edited the post after initially appending, because it only mentioned IC613 when I first read it, but now you say you're using IC614 (the version you gave is only a partial version number, as it should have an additional subnumber on the end to say which subversion you're using). Why you're reading documentation from a different version than the one you're using, I'm not sure, but never mind. This is not documented in the schematic documentation - but if you search in cdnshelp for nlIgnore, you'll find it.
    I tried with the "spectre" netlister in ADE in IC613 Base, 6.1.3.500.19, IC614 Base, 6.1.4.500.13 and it worked in all. This is not surprising, because it was implemented in an IC612 hotfix, according to CCR 263562.
    It does not however work with the AMS cell-based netlister ("ams") in ADE. This is covered in existing CCR 107333. That netlister is very different from standard ADE netlisters, so doesn't follow the same infrastructure. However, it also wasn't working in the AMS-OSS netlister either (from some tests that I did some time ago, also mentioned in the same CCR) - maybe it has been fixed in the meantime, as I've not re-tested that part recently.
    You could use the bind-to-open capability in the hierarchy editor to achieve the same effect though - so maybe you could use that. Or get a duplicate CCR filed with explanation as to your need,
