  3. ADE XL Monte Carlo Simulation: "Error evaluating ocean expression...
  • Replies 15
  • Views 11484
ADE XL Monte Carlo Simulation: "Error evaluating ocean expression"
lperktold
lperktold over 15 years ago
 Hello All,
 I am experiencing a rather strange behavior of ADE XL when it comes to evaluate the expressions defined in the
'Outputs Setup' section during a monte carlo run.
 The simulation stops (after the first run has finished) with an error like:
 ERROR (SPECTRE-8003): designParamVals: Error evaluating ocean expression `DE_1_I_Bias_6_45=average(IT("/I0/I0/I0/T7/D"))'.
 If I disable all the expressions in the 'Outputs Setup' pane the simulation runs fine. I can then use the 'Re-evaluate Result' button in the 'Results' pane to evaluate my defined expressions without any problems.
 I am using
- Spectre Version 7.1.1.187.isr11 64bit -- 18 Aug 2009
- Virtuoso version IC6.1.4.500.3
 Anybody else, experiencing this kind of strange behavior?
Cheers,
         Lukas
    Please contact customer support. I recall there being an issue with Monte Carlo in a certain range of spectre versions, so you might want to try running with the latest MMSIM hotfix first (I can't find the details though from a quick search).
    I thought initially it might be an issue with plotting waveform expressions with Monte Carlo, but the expression you have their should be producing a scalar result.
    As a workaround, you might want to try turning off running the "nominal" run from the Monte Carlo options form in ADE XL.
  • lperktold
     Hello Andrew,
     disabling the "Run Nominal Simulation" option under the Monte Carlo Simulation Options really did the trick. Now the defined expressions get correctly evaluated and the monte carlo simulation finishes without any errors.
     Thanks a lot Andrew for that useful peace of information.
     Cheers,
          Lukas
  • LucaPico
    LucaPico over 15 years ago
    Hy Andrew,
    i have the same problem (ERROR-8003) but i want to write the code as the following in order to avoid the script from stopping. (the script stops beacuse in the fprintf statement the results don't have the kind (e.g. %f) i specified.
    results = .....
    it gives me error
    if ((result == ??) then
    fprintf(file_port "ERROR")
    else
    fprintf(file_port "%f" results)
    I tried to put "nil" NaN" in the ?? field but it doesn't go into the if statement.
    Could you tell me what it is written in one expression when it's not evaluated?
    Thanks again
    Luca
  • ramadan
    ramadan over 14 years ago
     hi andrew
     i had the same problem that this guy had but i am using ADE L Monte carlo NOT XL ,and while i looked for montecarlo option there isnt
    any my cadence version is ic5141 ,and i am trying to do a monte carlo simulation ,and here is the spectre output
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 6.2.1.197 -- 13 Mar 2008
    Copyright (C) 1989-2007 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Protected by U.S. Patents: 5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238; 6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964; 6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839; 6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782; 7,085,700; 7,143,021.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    Simulating `input.scs' on faith at 3:51:07 PM, Thur Sep 8, 2011.
    Command line:
        /usr/local/cadence/mmsim/tools.sun4v/spectre/bin/32bit/spectre -env  \
            artist5.1.0 +escchars +log ../psf/spectre.out -format sst2 -raw  \
            ../psf  \
            -I/usr/local/ibm-13/IBM_PDK/cmrf8sf/V1.3.0.1DM/Spectre/models  \
            +lqtimeout 900 -maxw 5 -maxn 5 input.scs
    Loading /usr/local/cadence/mmsim/tools.sun4v/cmi/lib/5.0/libinfineon_sh.so ...
    Loading /usr/local/cadence/mmsim/tools.sun4v/cmi/lib/5.0/libnortel_sh.so ...
    Loading /usr/local/cadence/mmsim/tools.sun4v/cmi/lib/5.0/libphilips_sh.so ...
    Loading /usr/local/cadence/mmsim/tools.sun4v/cmi/lib/5.0/libsparam_sh.so ...
    Loading /usr/local/cadence/mmsim/tools.sun4v/cmi/lib/5.0/libstmodels_sh.so ...
    Using new Spectre Parser.
    Auto-loading AHDL component.
    Finished loading AHDL component in 0 s (elapsed).
    Installed AHDL simulation interface.
    Notice from spectre during topology check.
        No connections to node `0'.
        No DC path from node `clk' to ground, Gmin installed to provide path.
        No DC path from node `a0bar' to ground, Gmin installed to provide path.
        No DC path from node `a0' to ground, Gmin installed to provide path.
        No DC path from node `I0.T9:int_s' to ground, Gmin installed to provide path.
        No DC path from node `b0bar' to ground, Gmin installed to provide path.
            Further occurrences of this notice will be suppressed.
    Circuit inventory:
                  nodes 165
              equations 799
                  bsim4 317
    Notice from spectre.
        4 notices suppressed.
    Monte Carlo Analysis `mc1': iteration = (1 -> 100)
    awaiting artil process initialization ....
    **** Performing nominal run for `mc1'
    modelParameter: writing model parameter values to rawfile.
    element: writing instance parameter values to rawfile.
    outputParameter: writing output parameter values to rawfile.
    designParamVals: writing netlist parameters to rawfile.
    primitives: writing primitives to rawfile.
    subckts: writing subcircuits to rawfile.
    Error found by spectre during Monte Carlo analysis `mc1'.
        ERROR (SPECTRE-8003): subckts: Error evaluating ocean expression `path_1_delay_r=delay(VT("/clk") 0.6 5 "rising"
                VT("/c5") 0.6 4 "falling" 0 0 nil nil)'.
    Unsuccessfully evaluated export statements (based on return code).
    Analysis `mc1' was terminated prematurely due to an error.
    Aggregate audit (3:51:13 PM, Thur Sep 8, 2011):
    Time used: CPU = 2.27 s, elapsed = 6 s, util. = 37.8%.
    Time spent in licensing: elapsed = 40 ms.
    Virtual memory used = 23.1 Mbytes.
    spectre completes with 1 error, 0 warnings, and 11 notices.
    please let me know if you can help me for that or if you need more info
    you can email me on ramadan.buzakuk@yahoo.com
    thanks
    Hard to tell without seeing it, but I would suggest running with a current version of spectre (e.g. MMSIM10.1) to see if that fixes it. Otherwise there may be an error in your calculation. If that doesn't help, please log a service request so that we can take a look at the data.
  • ramadan
    i was able to remove the error at least for now by running a run on spectre and setting the delays from there ,and then run my monte carlo after that using the same state "wierd" ,any how i am getting mean and standard deviation to monte carlo run i want to know the formul to use to generate the same data in excel using my mcdata .pleaselet me know where i can find the formula for cadence mean and strandard deviation ram_kuky11@yahoo.com i work in a university ,so i dont have a host id to get a function for mean and std deviation from inside cadence
  • trdastidar
    trdastidar over 14 years ago
     I am facing a similar (but stranger) problem.
    I am creating a Spectre input file (with monte carlo simulation) on the fly, and then simulating it. To do this, I am copying the "amap" directory from the ADEXL simulation directory to the current directory.
    So, here are the steps:
    rsync -az /adex/directory/amap /current/directory
    spectre <options> <input_file>
    This works perfectly fine when I invoke the above two commands from either a command line, or a shell script.
    Problem is: when this is invoked from inside another C program, it throws up this error:
        ERROR (SPECTRE-8003): subckts: Error evaluating ocean expression `idc=(IDC("/V_IMON1/PLUS") + IDC("/V_IMON2/PLUS"))'.
    ... and similar such errors, right after the nominal simulation
     I have tried disabling the nominal, and the problem just gets pushed to the MC iterations, where it again fails to compute these quantities.
    Completely baffled by this strange behavior. Here are the troubleshooting that I have done:
    - Make sure that the amap directory gets copied properly - touch every file in there
    - Sleep after copying the directory
    Nothing works. At the same time, these commands run fine from the command line.
     Please help.
  • trdastidar
     By the way, I am using MMSIM101
  • trdastidar
     Some more bits of info, if this helps:
    - The nominal simulation goes fine (runs both DC and tran).
    - Problem occurs only when evaluating the expressions.
    - The dcOp.dc and dcOpInfo.info etc files are created properly in the psf directory.
    Well, that's a bit of a "hacked together" flow and a different problem from the one in the main thread - so would probably have been better as a separate topic (could always do a link to the other).
    There are some assumptions in the name mapping which expect the directory structure to be netlist (containing the netlist and amap dir) and psf alongside that where the simulation results go.
    So you might want to try that. Otherwise I'd suggest logging a service request (I don't have time to try this myself right now).
