  3. How to build a filter with its file-based characteristi...
  • Views 18785
How to build a filter with its file-based characteristics
800228
800228 over 16 years ago
Hello everybody,
We has been designing a system which includes a amplifier and a filter.
- We has designed the amplifier with cadence ADE tool.
- We will use an out-sourcing filter. We dont know the detailed implementation. We only know its characteristics (frequency response, group delay,...)
We want to check whole system by simulation. Is there anyway to build a filter as a component in cadence spectre with its characteristics in a file?
Any suggestions please share? Thanks alot
    Several ways:
    1. Use the Butterworth_filters or Chebyshev_filters categories of the rfLib library (<instDir>/tools/dfII/samples/artist/rfLib) (don't use the components prefixed BB as these are for baseband RF modelling).
    2. Use the ProgFilt component from bmslib (<instDir>/tools/dfII/samples/artist/bmslib)
    3. Use the Laplace controlled sources (e.g. svcvs, svccs, scccs, sccvs) in analogLib. These allow an s-domain representation of the filter
    4. Use nport from analogLib, and give it a file of s-parameters (scattering parameters) which define the impedances and transfer functions
  • 800228
    Thanks Andrew.
    Do you have any sample veriloga code of a filter?
    I would like to write a verilog code for the filter based on a sample code.
    Thanks again with best regards.
    The libraries I pointed you to (rfLib, bmslib) have VerilogA models. Also, "modelwriter" can produce an s-domain filter from a set of coefficients (although that's not rocket science).
  • 800228
    Andrew, thanks you. From your suggestion, I find out a way.
