  3. Generating S-parameters 8-port Sch from netlist
  • Views 15742
archive over 16 years ago
Dear All,
I have a netlist (.cir format) of an 8-port S-parameter model and I need to generate a schematic view in order to be able to simulate it using Spectre.
 I had a go using the import tool as following :
CIW->Import->spice In
but there is a problem with the components mapping I guess, the reference library I am using is the AnalogLib, Do I need a mapping file?
Please see below the first few lined of the netlist, I hope it helps:
_______________________________________________________________________________________________________
SPICE 2G6 netlist generated from [S] parameters
.subckt bckpanel_narrowband 1 2 3 4 5 6 7 8
* L in nH, C in pF
C1  1  0  8150.67985064037P
C2  1  2  843172.887981979P
__________________________________________________________________________________________________________
Regards
Nik
  • Quek
    Quek over 15 years ago
    Hi Nik
    You need a device map. Please use mappings similar to the pic shown below.
    Best regards
    Quek
