  3. Multipart path
  • Views 21208
Multipart path
frogconsultant
frogconsultant over 16 years ago
 Does someone know of the best way to load automatically the custom multipart path? Please can I have an example as well the procedure? I think we could do either through skill loading but the PDK I am using is uncripted so I am not sure I could add a line to be loaded automatically or through bindKey.
 Thanks in advance for your help.
    Bonjour!
    The simplest way would be to Create the multipart path interactively, and then on the Create Multipart Path form, use the "Save Template" and choose to save to an ASCII file.
    You should then be able to use this in your .cdsinit:
    load("~/gpdk090.mpp.templates.il")
    or whatever the file got called.
    There's no need to modify the PDK to do this - it will load an initialize the PDK, and then extend it to add your additional MPPs saved in this file.
  • frogconsultant
     Thanks.
    As I will need to use this automatic load in a debug proceed while I am building the multipart path, is it possible to reload by perhaps bindkey after I am already under VLE?
    Cheers
    OK, if you are changing the file by hand, then:
    hiSetBindKey("Layout" "<Key>F7" "load(\"~/gpdk090.mpp.templates.il\")")
    (change the key to whatever you want, and the file path to what you want. If you're editing the MPP definition through the Create MPP form, then there's no need to do this of course.
    Or you could use this function - load it and then call abLoadCodeGUI("/path/to/where/your/il/files/live")
    The code may look strangely familiar ;-)
    /* abLoadCodeGUI.il
    Author A.D.Beckett
    Group Custom IC (UK), Cadence Design Systems Ltd.
    Language SKILL
    Date Nov 23, 2006
    Modified
    By
    Main entry function is abLoadCodeGUI("pathname")
    Gives a form to make it easy to load SKILL code under
    development
    SCCS Info: @(#) abLoadCodeGUI.il 11/23/06.12:02:58 1.1
    * abLoadCodeGUICreateForm () *
    * Create the form the for code loading interface *
    (defun abLoadCodeGUICreateForm ()
    (let (files)
    (setq files
    (hiCreateListBoxField
    ?name 'files
    ?choices nil
    ?multipleSelect t
    ?doubleClickCB "abLoadCodeFilesCB(hiGetCurrentForm())"
    (hiCreateAppForm
    ?name 'abLoadCodeGUIForm
    ?formTitle "Load Code"
    ?fields (list (list files 0:0 500:400))
    ?attachmentList (list
    hicLeftPositionSet|hicTopPositionSet|
    hicRightPositionSet|hicBottomPositionSet
    ?initialSize 500:400
    ?buttonLayout '(OKCancel
    (Load abLoadCodeFilesCB)
    (Refresh abRefreshCodePathCB)
    ?callback 'abLoadCodeFilesCB
    * abRefreshCodePathCB (form) *
    * Callback for the refresh button *
    (defun abRefreshCodePathCB (form)
    (let (files currentValue)
    (setq currentValue (getq (getq form files) value))
    (setq files
    (sort (rexMatchList "\\.il[s]*$"
    (getDirFiles (getq form codePath)))
    'alphalessp))
    (putpropq (getq form files) files choices)
    (setq currentValue
    (setof value currentValue
    (member value files)))
    (putpropq (getq form files) currentValue value)
    * abLoadCodeFilesCB (form) *
    * Callback for the Load or OK buttons - also double click *
    (defun abLoadCodeFilesCB (form)
    (let (codePath fullPath)
    (setq codePath (getq form codePath))
    (foreach file (getq (getq form files) value)
    (setq fullPath (strcat codePath "/" file))
    (printf "loading code for %s\n" fullPath)
    (loadi fullPath)
    * abLoadCodeGUI (path) *
    * Main Entry point *
    (defun abLoadCodeGUI (path)
    (unless (boundp 'abLoadCodeGUIForm)
    (abLoadCodeGUICreateForm))
    (putpropq abLoadCodeGUIForm path codePath)
    (abRefreshCodePathCB abLoadCodeGUIForm)
    (hiDisplayForm abLoadCodeGUIForm)
  • frogconsultant
     I think I will go with the first approach for the time being. I am not so used to defun ...
    Subject closed
  • frogconsultant
    btw is there a translator from defun function to procedure function?
    Regards
    Note that you don't need to change the code I appended - it's a general purpose SKILL file loading utility (not very fancy, but it does the job).
    To convert from defun to procedure, and to output in C-like syntax, you can use pp()
    newFile=outfile("newCode.il")
    pp(abLoadCodeGUI newFile)
    pp(abLoadCodeGUICreateForm newFile)
    ; etc
    close(newFile)
    You lose all the comments by doing this, and the formatting is not that pretty, but it looks more C-like than LISP-like.
