  3. Unable to export CDL file
  • Views 19232
Renee
Renee over 15 years ago
I tried to export a cdl file from a small cell sw_dummy(it contains only basic MOS transistors), although it succeeded, the netlist was empty.
Then I tried to export the cdl from Calibre LVS function, but it failed. The error I get is: Netlister: unable to descend into any of the views defined in the view liste: "Cdl schematic" for instance M0 in Cell sw_dummy.
But the circuit designer can export cdl files successfully.
Then, I checked the si.env files, and I think I might find the problem:
In my si.env file, it defines:
 simViewList=`("cdl" "schematic") simStopList=‘("cdl") simSimulator='("cdl")
But in the ckt designer's si.env file, it defines:
 simViewList=`("auCdl" "schematic") simStopList=‘("auCdl") simSimulator='("auCdl")
I tried to change cdl to auCdl, but later I found that the si.env file changed it back every time I exported the CDL file.
Is there any way I can solve this problem?
 Thanks in advance!
    Before starting Virtuoso use:
    setenv CDS_Netlisting_Mode Analog
    Or if using bash or ksh:
    export CDS_Netlisting_Mode=Analog
    That should change the default CDL netlister to "auCdl". If using File->Export->CDL you get a choice of Analog or Digital on the form, but the Calibre interface may not give you that (not a Cadence tool,so I can't say).
  • Renee
    Thank you very much for your reply!
    I already solved this problem with your method.
    Although I could set the Netlisting Mode directly to Analog in the form of exporting CDL file in cadence, then it worked, however it did not change the variable CDS_Netlisting_Mode, thus I failed to export the CDL file when I started Calibre LVS and tried to export that file there. It seems that the Calibre LVS exporting CDL file tool relies on the cadence platform to perform the netlisting job.
