  3. How generate spectre netlist with model parameters
  • Subscribers 133
  • Views 5742
TiNat
TiNat over 15 years ago
Hi, My systerm info. as following: icfb : 5.10.41. I would like to find a method of generating spectre netlists which contains all model parameters. Now my netlist contain only path of model library. Thank you for your solution.
    Please do not post the same question in  multiple forums.
    At some point I plan to try to get some forum guidelines in place to make things like this clear, but in the meantime please just post in one place. If it's in the wrong place, we can move the post.
    See my answer to your duplicate post at /forums/p/16493/896066.aspx#896066
