  3. How to do more complex output tests in ADE-XL
  • Views 14442
SimonF
SimonF over 15 years ago
Hello, I'm pretty new to using ADE-XL,
I've set up a test in ADE-XL, and can get things to netlist, simulat and make simple measurements (like averages etc) and compare against specifications. So far so good.
But what if I have a more complex test to do, say I want to measure the maximum voltage on signal A that occurs at a rising edge of signal B but only at times where signal C is above a threshold.
 Does anyone have an example  of doing something like this they can share?
