  3. leHiCreateVia - soooo close
  • Views 1594
Michael Robinson
Michael Robinson over 15 years ago
What is the environment variable for the name of the via to place?
I've got all the other variables:
 envSetVal("layout" "viaMode" 'cyclic "Single")
 envSetVal("layout" "viaRows" 'int 2)
 envSetVal("layout" "viaColumns" 'int 1)
In CIW it's:
le0ViaForm->viaSingleModeScrollView->viaDefName->value="via3"
But I can find no environment variable like this when I do: Options->Save Defaults
with everything turned on.
  • skillUser
    skillUser over 15 years ago
    Hi Michael,
    I think that this is what you are looking for:
    envSetVal("layout" "useDefaultVia" 'boolean nil)
    envSetVal("layout" "userVia" 'string  "name_of_any_valid_via" )
    This was taken from Solution 11248244
    If the default via defined in the techfile is adequate, then set useDefaultVia to 't'.
    Lawrence.
  • Michael Robinson
    Thanks Lawrence, but I should have more specific.
    I'm using 6.1.4 and NOT using VXL.
    It appears in the solution they are using 5.1 and VXL.
  • Michael Robinson
    Lawrence,
    These are the messages I get when I try that solution:
    *WARNING* envSetVal: Can't set the value of variable 'useDefaultVia',
    in tool[.partition] 'layout' - it has not been registered.
    nil
    envSetVal("layout" "userVia" 'string "via1" )
    *WARNING* envSetVal: Can't set the value of variable 'userVia',
    nil
