  3. CDF parameters and AMS netlister
  • Subscribers 129
  • Views 13547
ArjanVanHeusde
ArjanVanHeusde over 15 years ago
Hi, I'm trying to do a mixed signal simulation with AMS. In my analog design i use CDF parameters to set transistor sizes. However, the components from the tech-lib i use calculate area values from the length and width values. Because of the Ppar("var") value of the sizes, the area calulation is not evaluated. The AMS netlster.log says "Error: Found a user defined function "int" in value of propert", where 'int' is part of the calculation. Is there some way to let these calculation be evaluated before the netlister starts, or by the netlister itself? thanks.
