  3. Virtuoso schematic editor: how to draw diagonal line?
  • Views 39813
archive over 15 years ago
 I know diagonal lines can be drawn on schematics. After checking the manual, still can not find it.
  • skillUser
    skillUser over 15 years ago
     While adding a wire (is that what you mean by a line in the schematic?) press the F3 key and change the Draw Mode from the default of "route" to something that allows diagonal or any angle wires.
    I think this is what you are looking for, but if not, supply more details and you might get further help.
    Lawrence.
     Hi Lawrence:
    This is exactly what I am looking for. Thanks a lot.
  • fomin
    fomin over 15 years ago
    I preffer another way. When I drawing a wire I click the right mouse button until schematic editor will be entered into "Any angle" mode.
  • skillUser
    It is the Right Mouse Button (RMB) to "Toggle Drawing Mode" using the IC5141 release, but this is now the Middle Mouse Button (MMB) in the IC61x releases.
    regards,
    Lawrence.
