  3. Have you found the .Xdefaults settings to change the background...
  • Subscribers 136
  • Views 16118
Have you found the .Xdefaults settings to change the background colors in IC6.1?
Michael Robinson
Michael Robinson over 15 years ago
 In IC5.1, I had pretty good control over the background colors of the CIW, editor window and LSW.
But in IC6.1, those controls seem nil.
I makes no sense that the editor window can be black but not the LSW window. The colors and fills
appear completely different.
What is the .Xdefaults setting to make the LSW background black?
Is it done a different way now?
  • berndf
    berndf over 15 years ago
     There is a .cdsenv environmet variable
    layout useEditorBackgroundColorForLSW
     which type is boolean and can be set to t or nil
    Bernd
  • Michael Robinson
     That is helpful. Thanks.
  • Michael Robinson
    Mr. Berndf sir,
    How did you find that layout variable?
    I've looked through the menus and don't find that setting.
    Usually, I would find the menu setting, save the user defaults and look for the differences in the .cdsenv.
  • chanakaya
    chanakaya over 15 years ago
    Hi Michael, If you want to get a complete list of all env variables for a particular tool, look under {IC61 Install Dir}/tools/dfII/etc/tools There will be .cdsenv file in each of the folders under that location with a listing of all the env variables corresponding to that tool. regards A Thomas
