  3. LVS Inverter
  • Views 19367
LVS Inverter
Anish7015
Anish7015 over 15 years ago
Hi
After I extract my layout of my inverter  I run LVS and I get an error saying: "the LVS job has failed to run to complete,Examine si.out and si.log in the run directory for more information". I re drew my schematic and did the layout.I still cant get that error to go away.
    Did you examine the si.out and si.log in the run directory for more information?
    How do you expect anyone else to help solve your problem with so little data? I can probably guess that you're using Diva LVS (you didn't say) - but you didn't say the version you're using, what the error messages in the si.out or si.log file are, etc, etc/
    Sorry to be blunt, but vague questions will get vague answers.
  • Anish7015
     Sorry about that. I am student using cadence for one of my digital layout class. I did figure out the problem. Every time I change something in my layout I had to save it and re start cadence. For some reson it seems to work after that.
  • Anish7015
     And one more thing I am using DIVA LVS. I am also using TSM_02 library.
    There's absolutely no need to restart "cadence" after saving (whatever "cadence" is...). You probably were not saving (and in the case of the schematic, you need to check-and-save). But this is just a wild guess and the errors in the si.log and si.out should have explained it.
    Best Regards,
