  3. Porting Layout is Virtuoso Layout to Encounter
  • Replies 12
  • Subscribers 137
  • Views 21942
nick83
nick83 over 15 years ago
Hi all,
I am new to this forum. I have recently started integrating my first test chip.
I have following problem:
My analog block is laid out in Virtuoso Layout editor and by digital block in Encounter.
How can I port my layout from Virtuoso Layout editor to Encounter. I am very new to Encounter. Can any one tell me some method by which I can port my design from layout editor to encounter where I can combine the two blocks?
Please provide me your suggestions and inputs.
Regards
Nick
  • Ada Shaine
    Ada Shaine over 6 years ago in reply to Quek
    Hey I am having trouble running LVS. It says while running the LVS that assura LVS run from..../failed.! The log file is at....
    What to do with this?
    Andrew Beckett over 6 years ago in reply to Ada Shaine
    Well, first read the forum guidelines because you've managed to break numerous of the guidelines. Posting on a 10 year old thread which is unrelated to your issue, and then posting the same question in more than one old thread is the main issue.
    Please start a new thread with sufficient information (you've given virtually nothing).
