  3. I can't vary temperature in transient analysis
  • Subscribers 133
  • Views 4652
TiNat
TiNat over 15 years ago
Hello. Recently I have found the method varying temperature in transient analysis. I have tried repeat it, but I can't. I have created the following file: pset1 paramset { time reltol temp : 0 1e-3 27 100m 1e-3 50 500m 1e-4 75 1 1e-5 125 } and I've added paramset=pset1 to additional parameters in tran options. When I was running the simulation the output log file was like that: Simulating `input.scs' on tim-desktop at 9:26:09 PM, Mon Sep 27, 2010. Using new Spectre Parser. Error found by spectre during circuit read-in. "/home/tim/projects/TNY266/temp.scs" 2: Unexpected colon ":". spectre terminated prematurely due to fatal error. When I've deleted ":" from my file, the simulation started but the temperature wasn't vary. Help me please, why it occured? Thank you for your solution.
    Did you try splitting it over several lines:
    pset1 paramset {
    time reltol temp
    0 1e-3 27
    100m 1e-3 50
    500m 1e-4 75
    1 1e-5 125
    I think (without checking or testing) that the line of parameter names needs to be separate.
  • TiNat
    I splitting it over several lines in my file but at forum all line were wrote in one line. The syntax of my file is like you suggested.
    Which version of spectre were you using? I've attached a zip file containing a netlist (tvary.scs) and the resulting log file from spectre, and a png file showing a picture of how the voltage across a resistor changes throughout the simulation. It works fine for me...
    tvary.zip
  • TiNat
    My system info. as following: icfb : 5.10.41; version of spectre is 6.0.2. Does this version of spectre support variation temperature in transient analysis?
    Dynamic parameter support was added in MMSIM62. So in the release you're using you can define a paramset but you cannot specify a paramset=pset1 parameter on the tran analysis. I'd expect you to see a warning about this in the spectre output.
    Is there a good reason to be using a 6 year old version of spectre? There have been 5 major releases of MMSIM since then (and there is another one due very soon) so there is very little good reason to use such an old version.
  • TiNat
    I try to account for using old version of spectre. I'm learning the Cadence Software, but as an illustration I use the circuits that were developed a long time ago and were in old versions of Cadence and I try to simulate in MMSIM 6.0 . Of course, In future I'll use new version of spectre.
