  3. how to change the model used by an instance
  • Views 15441
battu
battu over 15 years ago
say i want to change the model of a instance .
i created the model and i stored it.  now how to make the instance to use the model that i have created.
regards
  • Quek
    Quek over 15 years ago
    Hi battu
    Would you please provide more info on your question?
    a. What is the tool that you are using? E.g. Virtuoso schematic editor
    b. What is the version? Execute "virtuoso -W" or "icfb -W" in a terminal window
    Quek
  • skillUser
    skillUser over 15 years ago
    There really is not enough information in the question to answer!
    I'll make a guess to see if it helps...
    I'm assuming that you are changing the "model" parameter value on an instance in a schematic?  The model is what is used by the simulator to know which model to use to represent the device in the circuit for simulation.  So, make sure that the schematic has been "Checked & Saved" and (re-)netlist the design for the target simulator (e.g. Spectre), and then (re-)run the simulation - the new model should be present in the netlist and used by the simulator.
    Hopefully this helps, but if not, supply more information (which tool, which version etc. as Quek rightly asked, which simulator).
    regards,
    Lawrence.
  • battu
     Thanks for the reply...i have got the solution..
