  3. Warning : QTreeView :: rowsInserted internal representation...
  • Views 14923
Warning : QTreeView :: rowsInserted internal representation of the model has been corrupted, resetting.
Charley Chen
Charley Chen over 15 years ago
Hi All,
When I using  File -> Import -> Stream ,  Launch  the Browse Button for  "Stream File" Filed,
It occurs the message and the  files/dir not what I want.
The path the form  display  is not the same as I launch the command.
How to  solve it?
PS : IC 6.1.4 ISR4 & ISR7 is the same situation.
Thank you,
Charley
    Charley,
    I've found a small number of reports of similar messages, although not from the Import Stream command.
    My suggestion would be to move ~/.config to be called something else (e.g ~/.config_moved) and see if the problem goes away (you should restart virtuoso after doing this).
    Otherwise, I think you'll have to contact Cadence Customer Support via http://support.cadence.com . Even if it is the .config directory, I don't know what within that directory is causing the problem.
  • Charley Chen
    I found ~/.config and rename it  and restart virtuoso ,It works.
    Thank you,
    Charley
