  3. Function `pPar' is undefined or is used recursively.
  • Views 6601
gsimard
gsimard over 15 years ago
I have a component A which contains B, which itself contains C.  C instantiates some transistors and uses pPar("width") as their width, B uses pPar("width") as the width of C, and finally in A I give numerical values to the width of B. Spectre refuses to run however, complaining that "Function `pPar' is undefined or is used recursively.".
Any idea what went wrong there ?
Guillaume
  • Quek
    Quek over 15 years ago
    Hi Guillaume
    Please see if COS solution 1839188 helps you. Please ensure that "CDS_Netlisting_Mode" variable has been set to "Analog". You need to have the following line in your .cshrc file:
    setenv CDS_Netlisting_Mode "Analog"
    Best regards
    Quek
