  3. Open Instance connections Assura LVS error
  • Replies 14
  • Subscribers 136
  • Views 23334
jdgriggs
jdgriggs over 15 years ago
Simple inverter as a Ring Oscillator Design is DRC clean but the Assura LVS brings up Nets Mismatch Tool...Open Instance Connections...
I've tried severval ways to remove error but to no avail.  Any insight will be appreciated.
attach are the screen shot
  • jdgriggs
    Here's a shot with the diffusion region
  • jdgriggs
    Hey  Quek
    just wanted to follow-up on our conversation to see if you had any more insight
  • Quek
    Quek over 15 years ago
    Hi JG
    Thanks for the files. Unfortunately I can't find any more clues in the files too.It looks like it is better for you to file a service request to Cadence support for this issue.
    Best regards
    Quek
  • Ankurc
    Ankurc over 15 years ago
    There are some rewiring messages suggested by the assura at the end. Please try them. You can also try setting avCompareRule autoPinSwap(nil) during LVS run to disable the automatic pinswaping. Regards, Ankur
