  3. abstract warning ABS-1007
  • Views 15491
coffeelox
coffeelox over 15 years ago
While I tried to generate abstract.pin in abstract, I got following warnings. Can I ignore them? especially for the 1st two warnings, I don't know what they mean...
WARNING   (ABS-1007): Cell PAVSS: schematic and abstract.pin views terminal vss have different types
WARNING   (ABS-1007): Cell PAVSS: schematic and abstract.pin views terminal vdd have different types
WARNING   (ABS-1004): Cell PAVSS: schematic view does not have a terminal named sub!
WARNING   (ABS-1089): Cell PAVSS: has no output terminals
Thanks...
  • skillUser
    skillUser over 15 years ago
     Did you try looking at the documentation?
    Here are some snippets that might help:
    ABS-1007
    Message:
    Cell name: viewtype and viewtype views terminal name have different types. Select Cell – Terminal Properties to change the terminal type, or change the type in the view source file.
    Description:
    The Verify step has found inconsistencies in the terminal type settings for terminal properties in the layout and logical views.
    Troubleshooting:
    For information about changing terminal types, see Viewing and Editing Cell Terminal Properties .
    ABS-1004
    Message:
    Cell name: viewtype view does not have a terminal named name. Update the logical file to include any missing terminals.
    Description:
    When comparing layout and logical terminals, the abstract generator discovered that the logical view is missing from one or more terminals.
    Troubleshooting:
    Add information about these terminals to the logical view data.
    ABS-1089
    Message:
    The name cell has no output terminals, value cells without any output terminals.
    Description:
    There are no output terminals defined in the specified layouts.
    Troubleshooting:
    For the design to be valid, you must define an output terminal.
    After checking the above, let me/us know if you still have questions or problems.
    Lawrence.
  • coffeelox
    Thanks for quick response! Yeah, I did read the doc, but I don't understand why there are warnings... so I guess they might be ignorable...?
    In my schematic, I defined vss as "inout", and in abstract, I saw its direction is "inout" and its termType is "ground", so it should be match, why it said they have different types?
    for the last two warnings, I guess I can ignore them as well?
    1st one is for substract global contact.
    2nd one is because this pad is doing ESD protection, it consists of vdd, vss and esd protection circuit in between. vdd wire is part of the vdd ring connected to neighbour vdd pad. vss wire is provided by this pad and go to vss ring to provide vss connection for other pads. As the wire has been defined for vss inout, I guess I could not define the same wire as input or output for core power supply, however it's there. so I guess I could just ignore it?
