  3. VerilogIn pin notation
  • Subscribers 132
  • Views 15785
TjaartOpperman
TjaartOpperman over 15 years ago
Hi Everyone,
I am attempting to import a verilog netlist but need to retain the bus notation of pins as square brackets. Currently, notation for pins in the verilog netlist is denoted as data[7:0], but would be imported as data<7:0>. Is there a option available to prevent this conversion to "triangular" brackets?
Tjaart
    No. They should be angle brackets. Tools use different namespaces, and so CDBA (what Virtuoso uses) uses angle brackets as its bus delimiter. Similarly other tools use () or [. If you were able to convert the names to [ in Virtuoso, it would have no idea that they are busses, which is definitely not what you want. The idea is that names should be mapped as you move between different namespaces (i.e. use different languages).
