  3. strmout: ERROR: IUS hierarchy pointed to by the user path...
  • Views 2091
strmout: ERROR: IUS hierarchy pointed to by the user path (/usr/path) does not have a proper library ...
Charley Chen
Charley Chen over 15 years ago
Hi All,
When I using IC 614 ISR7 , File -> Export-> Stream , It seems fhas ininhed stream out.But I check the gdsii file is old.
IIn CIW , it shows as below:
strmout:   ERROR:  IUS hierarchy pointed to by the user path (/usr/local) does not have a proper
              library ; neither  /usr/local/tools.lnx86/lib  nor /usr/local/tools/lib exist.
strmout completed.
But I check the /usr/local is exist.But the other two path is not exist.
How to solveit ?
Thank you,
Charley
  • skillUser
    skillUser over 15 years ago
    Hi Charley,
    Perhaps strmout is trying to pick up something from the path and there is an IUS installation in the path before the IC614 tools?  Try again with the tools/bin and tools/dfII/bin from the IC614 installation in the path first, or at least before any IUS stream.
    Lawrence.
  • Charley Chen
    Hi Lawrence,
    I have set the ISU Path , But it's not the problem.
    I remove  /usr/local/tools from my PATH environment and the type strmout ,
    The message no more appears and It can find the path ,
    Now , why do I have to remove /usr/local/tools from PATH ??
    Can't I have this path ?? (/usr/local/tools)
    Thank you,
    Charley
    Charley,
    Please log a service request via support.cadence.com - I think some detailed analysis is needed.
