  3. Measure across a component in cadence ic 6.1.3
  • Subscribers 132
  • Views 14762
jun1119
jun1119 over 15 years ago
Hi
How can I make measurement across components such as resistor and capacitor in cadence ic 6.1.3? For example across R0 or C0 in this circuit
[URL=http://img512.imageshack.us/i/screenshotgk.png/][IMG]img512.imageshack.us/.../URL]
It seems to do not have a 2 point probe as in Pspice. I have tried the calculator function but it come out with some errors which I could not understand at all.
[URL=http://img686.imageshack.us/i/screenshot1nml.png/][IMG]img686.imageshack.us/.../URL]
Thank you
Zheng
    In general, you would subtract the difference between two node voltages as you've done. However, VDC is only relevant if you've done a dc (operating point) analysis - maybe you should have used VT()?
