  3. Techfile, GDS Import, Layout DRC Verification
  • Views 14187
StreamCX
StreamCX over 15 years ago
I have My_ADC ( cds6 project initially )project with cds.lib containing link to cds.lib file of DRC Project and techfile project.
I have layout in GDS converted to use in My_ADC by import.
I have convert layout from GDS to My_ADC using standard Cadence tech.lib but I need convert this by using my tech.lib
I have DRC Rules Project (cds5 converted to 6).
I have techfile project where I keep techfile.db and file with ext .oa. That files were maked from copying them from converted DRC project.
Convertion of DRC project from cds5 to 6 format was with no errors.
When I try to load layout from My_ADC project using DRC rules from DRC Rules Project project, error and warnings appears (in file).
When I try to verificate layout, IC crushed with panic error.
When I try to reimport GDS layout another errors appears, and error messages are different depending of what I have write in attach techfile tab in FILE/Import/STREAm
1) Attach  technology library field is "cdsDefTechLib"
Loading transUI.cxt
XStream/strminui is running (PID = ipc:3 )...
*WARNING* ddLibDefListCallback::onLoadWarnings: libdef file 'lib.defs' load warning:
 'Unable to open library test at path /home/starsa/lib018/Myxnor/./test: Invalid Lib Path'
*WARNING* The directory: '/home/starsa/lib018/Myxnor/test' does not exist
        but was defined in libFile '/home/starsa/lib018/Myxnor/cds.lib' for Lib 'test'.
INFO (TECH-150003): The technology database "cdsDefTechLib" has been automatically
updated from revision 226610(DM 0) to revision 227612(DM 0)
in virtual memory. It will be opened in 'a' mode for you to save it to disk.
*WARNING* (TECH-250037): The technology database "cdsDefTechLib" has been automatically
updated from revision 226610 to revision 227612 in virtual memory,
but is not good to be saved to disk because Attempt to save a read-only technology database.
*WARNING* : A Layer Number conflict has been detected in the technology hierarchy.
     It is caused by the following list of layers: My_ADC/L20 (#20); cdsDefTechLib/cutactive (#20);
*WARNING* : A Layer Name conflict has been detected in the technology hierarchy.
     It is caused by the following list of layers: My_ADC/L26 (#26); cdsDefTechLib/L26 (#26);
     It is caused by the following list of layers: My_ADC/L16 (#16); cdsDefTechLib/L16 (#40);
     It is caused by the following list of layers: My_ADC/L16 (#16); cdsDefTechLib/cpimp (#16);
     It is caused by the following list of layers: My_ADC/L52 (#52); cdsDefTechLib/L52 (#48);
     It is caused by the following list of layers: My_ADC/L52 (#52); cdsDefTechLib/mcap (#52);
     It is caused by the following list of layers: My_ADC/L22 (#22); cdsDefTechLib/L22 (#19);
     It is caused by the following list of layers: My_ADC/L22 (#22); cdsDefTechLib/L39 (#22);
     It is caused by the following list of layers: My_ADC/L41 (#41); cdsDefTechLib/dummy (#41);
     It is caused by the following list of layers: My_ADC/L32 (#32); cdsDefTechLib/L32 (#37);
     It is caused by the following list of layers: My_ADC/L32 (#32); cdsDefTechLib/poly1txt (#32);
     It is caused by the following list of layers: My_ADC/L13 (#13); cdsDefTechLib/L13 (#46);
     It is caused by the following list of layers: My_ADC/L13 (#13); cdsDefTechLib/poly2 (#13);
     It is caused by the following list of layers: My_ADC/L17 (#17); cdsDefTechLib/ckimp (#17);
     It is caused by the following list of layers: My_ADC/L53 (#53); cdsDefTechLib/mdiod (#53);
     It is caused by the following list of layers: My_ADC/L12 (#12); cdsDefTechLib/psv (#12);
     It is caused by the following list of layers: My_ADC/L8 (#8); cdsDefTechLib/nimp (#8);
     It is caused by the following list of layers: My_ADC/L6 (#6); cdsDefTechLib/cnimp (#6);
     It is caused by the following list of layers: My_ADC/L5 (#5); cdsDefTechLib/active (#5);
     It is caused by the following list of layers: My_ADC/L4 (#4); cdsDefTechLib/protn (#4);
     It is caused by the following list of layers: My_ADC/L3 (#3); cdsDefTechLib/protp (#3);
     It is caused by the following list of layers: My_ADC/L1 (#1); cdsDefTechLib/L1 (#45);
     It is caused by the following list of layers: My_ADC/L1 (#1); cdsDefTechLib/pwell (#1);
     It is caused by the following list of layers: My_ADC/L9 (#9); cdsDefTechLib/pimp (#9);
     It is caused by the following list of layers: My_ADC/L51 (#51); cdsDefTechLib/mres (#51);
     It is caused by the following list of layers: My_ADC/L7 (#7); cdsDefTechLib/poly1 (#7);
     It is caused by the following list of layers: My_ADC/L10 (#10); cdsDefTechLib/con (#10);
     It is caused by the following list of layers: My_ADC/L30 (#30); cdsDefTechLib/L30 (#0);
     It is caused by the following list of layers: My_ADC/L30 (#30); cdsDefTechLib/L27 (#30);
     It is caused by the following list of layers: My_ADC/L31 (#31); cdsDefTechLib/textu (#31);
     It is caused by the following list of layers: My_ADC/L15 (#15); cdsDefTechLib/me2 (#15);
     It is caused by the following list of layers: My_ADC/L11 (#11); cdsDefTechLib/me1 (#11);
     It is caused by the following list of layers: My_ADC/L14 (#14); cdsDefTechLib/via (#14);
*WARNING* Unable to set references on tech because conflicts would result in tech My_ADC.
ERROR (179): StrmIn has detected a conflict in the technology database graph. This could be because the technology library of the target library has conflict in its technology database graph or the specified reference technology libraries have a conflict with the technology library of the target library. Resolve the conflict manually before running the StrmIn application.
ERROR (79): Failed to attach technology file from the library cdsDefTechLib because a technology file already exists in the target library.
Translation Failed.
Or 2)
Attach  technology library field is empty
Product   : Virtuoso(R) XStream In
Program   : @(#)$CDS: strminui version 6.1.3 01/16/2009 01:23 (cic612lnx) $
          : sub-version IC6.1.3.500.6
Started at: 22-Oct-2010  15:40:35
User Name : starsa
Host Name : host
Directory : /home/starsa/lib018/Myxnor
CADENCE Design Systems, Inc.
Info: Cellview Rev Num:99,  Tech Rev Num:59
How can I fix this and verify layout?
  • layer5normalerror.txt
  • Quek
    Quek over 15 years ago
    Hi StreamCX
    It looks like your layout library has been attached to the default "cdsDefTechLib" library. This is not correct. It should be attached to the technology library provided by the foundry. You can change the attachment using "ciw:Tools->Technology File Manager->Attach".
    Best regards
    Quek
  • StreamCX
     Quek
    Thanks.
    I do that. But when I try import .gds file to library that i attached techfile this message appears
    "ERROR (74): Target library 'librarytest' is attached to the technology library 'techtest'. Therefore, technology file is opened in read-only mode. Use a layer map file to continue.
    Translation Failed."
    What I need to do?
    Abd another question - why I can`t attach tech file to libraries that I want?
  • Quek
    Hi StreamCX
    You are unable to import the gds file because layer mapping info is missing. In IC61, the tech directory should also contain a file named "techlib.layermap". For your case, it should be named "techtest.layermap". Xstream (the tool for importing/exporting gds) will automatically look for this file in the tech directory and read in the layer mapping. If this file is not present, user must then provide the mappings in the stream in/out form. Hence your gds import failed because neither info is present.
    Please check the actual tech directory that is provided by the foundry. There should be a layermap file in it. E.g. it might be named "chrt013.layermap" or "tsmc40n.layermap", etc.
    You can and should certainly attach your design libraries to the appropriate tech lib. If you are experiencing any errors in doing so, please post the error messages.
    Virtuoso techfiles can be in binary or ascii format. Usually we named the ascii format techfile with a ".tf" extension. An ascii format techfile can be imported into Virtuoso using the Technology File Mananger.
    Best regards
    Quek
  • StreamCX
     Quek
    Thanks.
    I found that file in my tech library. Problem was in that I earlier try to divide that library.
    But I have another question.
    For example, when I try import .gds file to destination library with path equal to tech library path, results are with no errors.
    But when they are different
    ERROR (79): Failed to attach technology file from the library techtest because a technology file already exists in the target library.
    Translation Failed.
    ERROR (76): Failed to open technology file `My_LIb` in the append mode. Therefore, automatic layer mapping cannot be done. Use the layer map file to continue.
    Translation Failed.
  • Quek
    Hi StreamCX
    Regarding your question on IC51 layermap file, the same map file can also be used for IC61 if the layer names and numbers are the same. If your destination library already is already attached to a tech lib or is a tech lib itself, then there is no need to specify tech lib attachment in the import gds form. I think you might have specified a different tech lib and hence resulted in the error.
    Best regards
    Quek
