  3. Nesting MC-per-corner simulation
  • Views 14768
Alonb33
Alonb33 over 15 years ago
Hello, I'm looking for a simple way to do nested Monte-Carlo simulation at each corners. One way is to write an ocean script that run MC changes corner run MC changes corners ..... This mean that i need to integrate CornerSweep.pcf/dcf into one ocean script. Is there a nicer way to do it like combining cornerRun() command with monteRun() so it will run MC for each corners defined at CornerSweep.pcf/dcf Regards, -Alon
    archive over 15 years ago
     If you have access to IC6.x you can do this easily with OCEAN-XL.  Have ADE-XL generate the script for you.
    Or better, just use MDL (works with Spectre and APS). Examples are in MMSIM*/tools/spectre/examples/MDL_workshop.
    Samir Jafferali
