  3. Errors while loading virtuoso (HitKit)
  • Replies 8
  • Subscribers 138
  • Views 20920
pitter
pitter over 16 years ago
I have recently installed newer version of virtuoso (6.1.4-64b). My PDK provider is AustriaMicrosystems (AMS). HitKit(version 4) has been installed with all updates available.
When I start virtuoso (by executing ams_cds command) there are some errors reported in CIW window:
COPYRIGHT © 1992-2009 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
© 1992-2009 UNIX SYSTEMS Laboratories INC.,
Reproduced with permission.
This Cadence Design Systems program and online documentation are proprietary/confidential information and may be disclosed/used only as authorized in a license agreement controlling such use and disclosure.
RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program: @(#)$CDS: virtuoso version 6.1.4-64b 08/02/2010 00:21 (sjfnl002) $
Sub version: sub-version IC6.1.4-64b.500.6 (64-bit addresses)
Loading geView.cxt
Loading menuBuilder.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ci.cxt
Loading ams.cxt
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.06s.
austriamicrosystems HIT-Kit v.4.00
COPYRIGHT (c) 2008 Full Service Foundry @ austriamicrosystems AG. ALL RIGHTS RESERVED
This HIT-Kit and attached documentation are confidential information and may only be used as authorized by the HIT-Kit license agreement.
Loading generic HIT-Kit skill context.
*Error* eval: unbound variable - menuIdPull
Loading the environment file.
*Error* eval: undefined function - darfidg
*Error* load: error while loading file - "/home/piter/Cadence/HitKit/cds/HK_ALL/skill/ams_env.ile"
*Error* load: error while loading file - "/home/piter/Cadence/HitKit/cds/HK_ALL/skill/ams_env.il"
Loading process specific call-back routines.
Loading amsEvalCB. Note: These are preliminary CallBacks.
Please report problems or suggestions to HITKIT@austriamicrosystems.com
function ams_ResCallback redefined
function ams_ResCapCallback redefined
function ams_CapCallback redefined
function ams_MosCallback redefined
function ams_HvmosCB redefined
function ams_check_DPTUB redefined
function ams_jfetCB redefined
function ams_isoCB redefined
Loading all available p-cell functions.
No mx check
ROD pcell code loaded
Loading default bindkeys.
Setting the prompt.
*Error* eval: undefined function - AMS_setPrompt
Loading ./.cdsinit_local file from .cdsinit file.
LOAD LOCAL CUSTOMIZATION.
END OF LOCAL CUSTOMIZATION.
Loading $HOME/.cdsinit_personal file from .cdsinit file.
END OF USER CUSTOMIZATION.
*Error* eval: undefined function - AMS_checkProcessOption
END OF SITE CUSTOMIZATION.
Loading rte.cxt
I also noticed that layers in LSW and Virtuoso layout suit are not recognized/visible. There is a bunch of warnings in CIW window like:
*WARNING* The display packet information 'SCSDD6' for 'display' was not found.
Moreover when I imported a design the cmos models where not found, that is I have to set them manually every time I start ADE in Setup -> Model Libraries... .
Kind Regards and many thanks in advance for help and suggestions.
Piotr.
  • pitter
     Well, somehow I found the solution myself. I have not explicitly writtenit in thepost, but I am using 64-bit version ofoperating system and cadence software.I had also license problems, that Isolved. After this the obove errors did not appear. So, if anyone has such a problem, inspect your license (flexlm)
  • EP89
    EP89 over 16 years ago
    edit: figured it out
  • pitter
    pitter over 15 years ago
     I cannot precisely say what actually solved the problem, but I assume that it was permission problem. As far as I can remember some components of cadence software were installed with root permission. And now before I start virtuoso I manually (as superuser root)) start license deamons amslmd and cadence lmgrd. It might solve your problem. Good Luck!
  • Hesham2012
    Hesham2012 over 14 years ago
    Hi
    I have the same problem and I tried to solve in tens of ways but no help
    Can anybody provide any suggestions?
    We just had the same question via customer support (possibly it was you?). Anyway, the right people to ask about this are Austria Micro Systems (AMS) since it's their design kit.
    Or if you're getting the kit via EuroPractice, ask them...
  • Hesham2012
    Thanks!
    I did :)
    But didn't get a solution yet.
    I just thought any body who faced the same problem before may help.
    My Regards
    Hesham
  • Hesham2012
    Hi
    I installed an updated from AMS for IC6.1.4 and the bug is fixed now.
    Hesham
