  3. input.scs generated from OCEAN removed some pxf analysis...
  • Subscribers 136
  • Views 15247
input.scs generated from OCEAN removed some pxf analysis options
QUBOZHOU
QUBOZHOU over 16 years ago
input.scs generated from ADE and OCEAN are different. for example, input.scs from ADE ... ... pxf ( dout 0 ) pxf extrasampletimepoints=[7n] + sampledelay=[-200p] crossingdirection=fall thresholdvalue=0.55 + sampleprobe=V0 ptvtype=sampled sweeptype=absolute start=64K + stop=64M dec=30 maxsideband=10 annotate=status input.scs from OCEAN pxf ( dout 0 ) pxf thresholdvalue=0.55 sampleprobe=V0 + moduppersideband=0 outmodharmnum=1 inmodharmvec=[1] + sweeptype=absolute start=64K stop=64M dec=30 maxsideband=10 + annotate=status some options are removed somehow. the ocean script is saved from ADE/Session/Save Ocean Script.. I am using IC613.
  • Oliver LZD
    Oliver LZD over 4 years ago
    Hi, QUBOZHOU
    I have meet the same problem of missing options when generating the OCEAN from ADE(pss+pnoise simulation). Then i found the missing part in the input.scs created through ADE-Simulation-netlist-create. It may be helpful.
    However, new problem come up that i have no idea how to translate the "input.scs" back to ocean. Do you have any suggestion?
    input.scs :
    pss  pss  fund=50K  harms=20  tstab=201u  autosteady=yes annotate =status
    pnoise pnoise start=1 stop=50M maxsideband=20 noisetype=sampled measurement=[pm0] annotate=status
       pm0 jitterevent measure=timesampled target=[x1p x1n] samplesperiod=1 samplephase=[0] samplepoints=[9u 18u 19u]
    OCEAN created:
    analysis('pss ?fund "50K"  ?harms "20"  ?tstab "201u"  ?autosteady "yes")
    analysis('pnoise  ?start "1"  ?stop "50M"  ?maxsideband "20"  ?oprobe""  ?noisetype "sampled"  ?noisetypeUI ""  ?noisetypeUI1 "sampled(jitter)"  ?sampleratio ""   )
    (pss successed  but pnoise failed because of "ERROR(SPCRTRF-15462): No jitter event measurement is defined")
