  3. vhdl behavioral code to schematic conversion in cadence
  • Views 16112
pmuppala
pmuppala over 15 years ago
hi, I implemented a binary search algorithm in vhdl using behavioral description. I imported this file from cadence and created a symbol for this.When i try to add this as an instance in any other schematic and simulate it, it shows an error saying that there is no view of type spectre.. How can i resolve this.. Thanks in advance, Muppala
  • croy
    croy over 15 years ago
     Hi pmuppala
    What Cadence tools are you using here?
    Chrystian
  • pmuppala
    I am using just virtuoso 6.1.3. I read in some previous posts that we need to have standard cell library with all the gates pre-declared inorder to import a verilog or vhdl code and use it..
    If you are trying to simulate VHDL behavioural code in spectre, it's not going to work. Spectre is a transistor level simulator and cannot simulate digital languages. You would need to use ncsim (or maybe AMS Designer if it has transistor level components as well).
