  3. Variable sizes
  • Views 14586
Variable sizes
Thodoros
Thodoros over 15 years ago
Is it possible to use a bus  with a variable size (i.e. bus<0:maxSize>) in schematic editor? (Where maxSize could be a global variable or a parameter to the library).
 Is it possible to use variable size for iterated names of instances (i.e. sramColInst<0:colSize>) or even for pin names?
It could be quite helpful to make a design flexible.
Is there an other way to walk it through?
Thanks in advance,
Thodoros
  • Quek
    Quek over 15 years ago
    Hi Thodoros
    Unfortunately, as of IC614.500.10, it is not possible for bus names or names of iterated instances to use a variable. Kindly request for this enhancement through your local Cadence support so that our R&D can evaluate if this can be implemented.
    Best regards
    Quek
