  3. Copying layout files from one library to Another Librar...
  • Views 19629
Copying layout files from one library to Another Library
sathisha
sathisha over 15 years ago
Hi Is there any way to copy the few cells layout from one library to another library at a time. (I need to update only Layout). Example: i have two library Test1 and Test2 in both the library i have the same number of cells but there layout is different. I need to update all the cells layout in Test2 from Test1 library. Thanks, Sathisha
    Hi Sathisha,
    In the Library Manager use Edit->Copy Wizard, and then go to the By View tab.
  • sathisha
    Thanks Andrew. --Sathisha
