  3. hotkey doesn't work in virtuoso schematic editor
  • Views 4568
Malolo
Malolo over 15 years ago
 I'm using tsmc 0.18rf pdk and everything works fine except that hotkeys dont work in virtuoso(schematic editor, or layout) Anyone had the  same problem, any clues?
 thanks,
  • Malolo
    I did some search online and sorta solved it by coping .cdsinit file into local directory. It works now except everytime I start icfb, error messages show in CIW, here's part of it:
     Loading ./.cdsinit init file from the site init file.
    END OF SITE CUSTOMIZATION
    *WARNING* (lookupTag): Can't open file /home/EDA/ic5141/tools/dfII/etc/context/schView.toc, because Too many open files
    *WARNING* (lookupTag): Can't open file /home/EDA/ic5141/tools/dfII/etc/context/schematic.toc, because Too many open files
     *WARNING* (lookupTag): Can't open file /home/EDA/ic5141/tools/dfII/etc/context/schHDL.toc, because Too many open files
     *WARNING* (lookupTag): Can't open file /home/EDA/ic5141/tools/dfII/etc/context/symbDRC.toc, because Too many open files
     *WARNING* (lookupTag): Can't open file /home/EDA/ic5141/tools/dfII/etc/context/analog.toc, because Too many open files
     *WARNING* (lookupTag): Can't open file /home/EDA/ic5141/tools/dfII/etc/context/stv.toc, because Too many open files
     *WARNING* (lookupTag): Can't open file /home/EDA/ic5141/tools/dfII/etc/context/verilogI.toc, because Too many open files
     *WARNING* (lookupTag): Can't open file /home/EDA/ic5141/tools/dfII/etc/context/StrctCmp.toc, because Too many open files
     *Error* load: can't access file - "leBindKeys.il"
     *Error* load: can't access file - "./.cdsinit"
    so what's going wrong here?
    thanks,
  • skillUser
    skillUser over 15 years ago
     Hi Malolo,
    A quick search for "lookupTag" revealed Solution 11363354 it mentions that this can arise if the samples/local/cdsinit example .cdsinit file is copied to a users' home directory without the removal of the part of the code that loads ~/.cdsinit - in this case it will get into a loop loading itself over and over and eventually run out of file descriptors (handles). Comment out that section or remove it so that the file is not recursively loading itself.
    Lawrence.
  • Malolo
     it works, thanks Lawrence!
    Malolo
