  3. Failed to compile ahdlcmi module library
  • Subscribers 133
  • Views 18231
Irun
Irun over 15 years ago
The icfb version is 5.1.0 06/24/2004 17:30, (only the base CDs), when I tried to simulate a circuit which module file contains ahdl_include "res_va.va" statement, it gets error saying that it can not compile ahdlcmi module library. (spectre outlog: ...
Failed to compile ahdlcmi module library, see
/home/michen/csmc05/CSMC05MS/models/res_va.va.ahdlcmi/ for details) Details is attached below:
ahdlcmicompile: Compiling ahdlcmi in /home/michen/csmc05/CSMC05MS/models/res_va.va.ahdlcmi/ for Linux2.6.9-89.ELsmp+gcc with optimize using gcc on Sat Nov 27 00:13:10 HKT 2010 [0]
ahdlcmicompile: Generating makefile
PATH: /home/IC5141/tools.lnx86/systemc/gcc/install/bin:.:.:/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/usr/X11R6/bin:/home/IC5141/tools/bin:/home/IC5141/tools/dfII/bin:/home/IC5141/tools/plot/bin:/home/IC5141/tools/dracula/bin:/home/IC5141/tools/jre/bin:/home/IC5141/tools/spectre/bin:/home/michen/bin:/home/IC5141/tools/bin:/home/IC5141/tools/dfII/bin:/home/IC5141/tools/plot/bin:/home/IC5141/tools/dracula/bin:/home/IC5141/tools/jre/bin:/home/IC5141/tools/spectre/bin:/home/IC5141/tools/systemc/gcc/install/bin
LD_LIBRARY_PATH: /home/IC5141/tools.lnx86/systemc/gcc/install/lib:/home/IC5141/tools.lnx86/mdl/lib:/home/IC5141/tools.lnx86/dfII/lib:/home/IC5141/tools.lnx86/lib:/home/IC5141/tools/lib:/home/IC5141/tools/systemc/gcc/install/lib:
Compiling C file installdev.c (optimize)
/home/IC5141/tools.lnx86/systemc/gcc/install/bin/gcc -ansi -march=i486 -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC -DconfigSPECTRE -I. -I/home/IC5141/tools.lnx86/spectre/ahdlcmi/include -c installdev.c -o obj/Linux2.6.9-89.ELsmp+gcc/optimize/installdev.o || rm -f -f obj/Linux2.6.9-89.ELsmp+gcc/optimize/installdev.o;
/tmp/ccquAzZh.s: Assembler messages:
/tmp/ccquAzZh.s:7: Error: suffix or operands invalid for `push'
/tmp/ccquAzZh.s:10: Error: suffix or operands invalid for `pop'
/tmp/ccquAzZh.s:18: Error: suffix or operands invalid for `push'
/tmp/ccquAzZh.s:20: Error: suffix or operands invalid for `push'
/tmp/ccquAzZh.s:24: Error: suffix or operands invalid for `pop'
/tmp/ccquAzZh.s:25: Internal error, aborting at ../../gas/config/tc-i386.c line 4022 in output_imm
I know many others have encountered this error before, and they got the advice to update to a newer version of the simulator.
But in the reference file spectreref.pdf(Product Version 5.1.41 June 2004) I found  it mentioned
"Verilog-A compilation
In this release the simulation performance of Verilog-A has been improved by performing a
one time compilation step. The performance improvement obtained is proportional to the
complexity and amount of Verilog-A in your design. Following the initial compilation,
recompilation will only be performed if the Verilog-A source is changed.
Verilog-A compilation is enabled by default. If you are making frequent changes to the Verilog-
A used in your design, the overhead of the compilation step may become an issue. To turn
off compilation  set the CDS_AHDLCMI_ENABLE shell environment variable to NO e.g:
Since this icfb version can compile Verilog-a, why i still got the above error? Is there something I've missed to setup in the environment file?
  • Irun
    And in the PDKUserGuide it says "the PDK was tested for use with Cadence IC 4.4.6 and IC 5.0 Release". It makes me think it's less likely related to software version.
    In those versions, there was no model compilation. Using spectre from IC5141 is really not recommended, since spectre has been in a separate stream since end the of 2004 (shortly after IC5141 was released), called MMSIM. There have been MMSIM60, MMSIM61, MMSIM62, MMSIM70, MMSIM71, MMSIM72 and now MMSIM101 releases since then - so you're using a version of spectre that is essentially 6 years old. There have been some issues with model compilation fixed since then, and certainly a lot of improvements.
    The errors should not stop the simulation running. I would suggest running a newer MMSIM version of spectre, and if that's not possible, set the  CDS_AHDLCMI_ENABLE environment variable to NO as suggested. This will not then attempt to compile the models, and so the errors will go away. But for best speed, you should really use a supported version of spectre.
  • Irun
    Thanks Andrew for explanation.
    Yes, those warnings/errors do not prevent the simulation, but that makes me uneasy and it's annoying. Setting CDS_AHDLCMI_ENABLE to NO works, thanks.
  • ROHIT DWIVEDI
    ROHIT DWIVEDI over 12 years ago
     sir i am working on CADENCE 6.1.5 and i am desighning a LNA using RF inductor and resistor of UMC_18_CMOS LIBRARY. it also produces the same simulation error ahdlcmi library module is not found. how can i attach this library to my cadence. i have the module library of cadence5.
    As in the Forum Guidelines please:
    1. Don't append to an old thread
    2. Please provide the relevant version number (the simulator in this case) that you're using
    3. Please give the exact error message.
    4. Please read the forum guidelines.
    Kindest Regards,
