  3. Nested dependent parametric sweeps
  • Subscribers 133
  • Views 14726
archive over 15 years ago
I'm using IC 6.1.4. with MMSIM 7.2.
I'd like to carry out some nested parametric sweeps where the range of one of the parametric variables is dependent on the other. So
  • Variable 1: Start 1, end 10, steps 10
  • Variable 2: Start Var1-0.1, end Var1+0.1, steps 10
 Is there any way I can achieve this in the parametric sweep tool or in ADE-XL? I realise this can be done fairly easily in Ocean so it's not a dead loss if the answer is no.
 Roger
