  3. sevsession connected to a schematic
  • Views 15070
swdesigner
swdesigner over 15 years ago
 When a schematic is first opened, and then the Virtuoso-ADE launched through tools, the window title is changed to reflect the index number of the ADE window. For example, it ends in "... schematic - Virtuoso (R) Analog Design Environment (3)". Then, a bindkey can be setup to use the title text to and issue a skill command to annotate node voltages and op info.
However, if the saved state is launched, and, through the results ADE instance, the schematic is opened, then, the title does not reflect the index number of this ADE instance.
In such a case, is there any way to find the ADE instance index number to make such bindkeys work?
    The right way to do this is to use:
    sevSession(hiGetCurrentWindow())
    Rather than parsing the window title.
  • swdesigner
    Thank you!
