  3. psf utility question
  • Views 15900
candygg
candygg over 15 years ago
              I use command "psf -fmt %.10g" to convert psfbin data to ascii format for high precision. While this works perfectly for tran.tran, I find it doesn't work for ac.ac.
              After converting ac.ac file to the readable format, for simplest case, you will see two signals: one is frequency, the other is the output signal in complex form: (real-part    imag-part). This complex data is always in 6-digit precision, while frequency data is 10-digit as what I've set. I wonder is this a bug or do I set anything wrong? Thanks for your help!
    I think this will need an enhancement to the psf utility, so please log a service request with http://support.cadence.com
    Best Regards,
  • Victor Spitsyn
    Victor Spitsyn over 11 years ago
    Is there the service request filed?
    I observed the same when doing output psfascii directly from Spectre.
    Having rawfmt=psfascii and precision="%24.17g" in simulator options, provides 6 digits only for AC analysis results.
    It works OK for tran and DC.
    - Victor
