  3. verilog auto-checker search paths
  • Subscribers 132
  • Views 16599
markbeck
markbeck over 15 years ago
Greetings all,
I've got a verilog cell view that contains the following statement:
   `include "foo.vh"
Now when I try checking the file with the following command:
   vmsUpdateCellViews(?lib "lib" ?cell "cell" ?view "verilog")
I get the following error:
    "cannot open include file "foo.vh"
I tried to set a include directory with the environmental variable:
    amsDirect.vlog incdir string "10-/blah/blah"
 (where the string is my path name)
But, it continues to fail.  If I run ncvlog from the command line using -incdir, it works fine.
Any ideas how to specify the include path for vmsUpdateCellViews() ?
Mark
    Mark,
    Please log a service request for this. It ought to be possible (run out of time to try it myself now), and if not, we need to make it possible somehow!
  • Ezequiel
    Ezequiel over 14 years ago
     Is there any update on this subject?
     Ezequiel
  • chrger
    chrger over 14 years ago
    You need a "hdl.var" file in the run directory, that contains the following line:
    DEFINE NCVLOGOPTS -incdir "path_to_verilog_files"
    Christian
