  3. DC Match in SpectreMDL
  • Views 14959
MarkSummers
MarkSummers over 15 years ago
I am looking to run two dc match simulations using spectreMDL.  I don't want to use the output values in the script(well I would but I know I can't), I just want to run the analysis.  I can get a current probe one to work fine.  However how do I define the voltage nodes to use.  Seems like it should be the same as noise, but the example listed in the manual is not clear to me about using voltages.  I could include a file that defined two different dcmatch analysises but I would prefer to avoid this if possible.  Any help is appreciated.
 I am using spectre 7.2 and ic5.1
  • MarkSummers
     The answer to this is that you have to setup an analysis in the netlist to make this work.  Probes work in spectremdl, but not node voltages.
