  3. Attach netname
  • Views 15461
Attach netname
Claes
Claes over 15 years ago
Is there a way to attach a netname of a wire in layout. (not Layout XL) ?
Thanks in advance,
Regards, Geert
  • Alex Soyer
    Alex Soyer over 15 years ago
    Hi Geert, Please first select your shape and then click on Connectivity -> Net -> Add Shape. Regards, Alex
  • Claes
    when I try this Layout complains about "Net does not exist". Does Cadence tries to refer to a schematic ?
    Regards, Geert
  • Amit  Biswas
    Amit Biswas over 15 years ago
    HI Claes. Question is not clear about what exactly you want. Any way I am putting my suggestion , it might help. simple way to put a net name is select the wire and press "q" to get the property window and put the net name in connectivity . Other way to do it in SKILL is cv=geGetEditCellView() obj=css() netname="put net name" netid=dbFindNetByName(cv netname) dbAddFigToNet(obj netid)
