  3. MonteCarlo simulations
  • Views 15175
Ueue
Ueue over 15 years ago
Dear all,
In my process I don't have the mismatch information in the section mismatch of the models.
Therefore, I cannot perform MC simulations for mismatch, but only for process variations.
In particular, in the section mismatch, I have these unsignificant (at least to me) lines:
mismatch {
vary parn1 dist=gauss std=1/1vary parn2 dist=gauss std=1/1
vary parp1 dist=gauss std=1/1
vary parp2 dist=gauss std=1/1
Since I have the information about mean value and standard deviation of the threshold voltage of the MOS I use, Is there a way to insert in the model this information, and to allow me to perform MC simulations?
Thanks a lot,
Stefano
    Hi Stefano,
    I'm slightly confused, as you say you don't have mismatch information, but then you show a mismatch section! It's possible that these are simple gaussian distributions which are then scaled within the models. For mismatch to work, the model needs to be parameterized and inside a subckt (often an inline subckt) - if the parameterized model is referencing these parameters parn1/parp1 etc then it should get some mismatch.
    See http://www.designers-guide.org/Modeling/montecarlo.pdf (the same document is on Cadence Online Support ).
