  3. spectre: fsdb output directly out of ADE
  • Views 24286
baenisch
baenisch over 15 years ago
Hi all
I'm working on a project based on IC6.1.3 with default MMSIM7.1 (which I can switch up to 10.1)
and I'm currently facing some large simulations and the waveform viewer is giving me the creeps ...
Therefore I tried some different formats that can be selected in the ADE Output Menu (sst2, psf ...)
but postprocessing, zooming and so on are still so sloooowwww. I searched through the
manual and found the possiblity to write fsdb.
My problem is, that I get fsdb outputs if I run spectre from the command line with the output
set to fsdb, but I can't get it to work if I start simulations directly from ADE. I already set
SPECTRE_DEFAULTS to -format fsdb but with no success. The switch seems to be
recognized, it's reported in the spectre-logfile but I don't get fsdb outputs :(
Can someone please give me some pointers on how to get fsdb as a default ?
At least until 6.15 is coming  with seems to get an all new waveform viewer
Best Regards
Andi
    Andrew Beckett over 15 years ago +1
    Andi, You might want to take a look at psfxl since that's a faster format which is supported within the environment. You need to be using a recent enough IC613 version (you need at least IC613 ISR14 and…
    Andi,
    You might want to take a look at psfxl since that's a faster format which is supported within the environment. You need to be using a recent enough IC613 version (you need at least IC613 ISR14 and MMSIM71 ISR13) - better still IC614 and MMSIM101.
    The trouble with writing fsdb is that various things will break if you use this. That's because ADE expects a format it can read for doing things like operating point annotation and so on. So it's really only supported for a command line flow.
  • baenisch
     Hi Andrew
    Thanks for the clarification. I switched to 10.1 and it's a bit faster now.
    For the big ones I'll switch to the command line and a different viewer
    Best Regards
    Andi
  • LDIL
    LDIL over 5 years ago in reply to Andrew Beckett
    Hi Andrew. Is this true for Maestro too?
    Andrew Beckett over 5 years ago in reply to LDIL
    Actually, it's not really anything to do with ADE L/XL/Explorer/Assembler, but more to do with the fact that things have changed since a response 10 years ago.
    You can (on Outputs->Save All) pick the output format to be "fsdb" and that impacts transient simulation; the other analysis types continue to output PSF. ViVA (in the meantime) supports reading FSDB too, so you can plot the transient data as well as handling the other output data formats.
    That said, unless you really need FSDB for other tools, I don't see much really to use it - PSF XL is smaller now as well as being fast (it has a lossless compression) for transient data and has been optimised for use with ADE.
    ShawnLogan over 5 years ago in reply to LDIL
    Dear LDIL,
    I am not Andrew, and will never pretend to be with his extended background and knowledge. Nevertheless,  this is 10 year old post, and many things have changed in the Cadence tools. To be honest, I am not clear on your specific question. Assembler and Explorer both can enable spectre to write its output data in  fsdb format. In Figure 1, from an Explorer session I happened to have open, I've circled the option to write spectre's data in fsdb format. I use this format for some tools that require it.
    Is that your question?
    Shawn
    Figure 1
