  3. auCdl netlist subckt missing parameters
  • Views 18022
Paulux
Paulux over 15 years ago
In auCdl netlist generation, I want to generate the netlist shown below
XI1 net16 gnd! / rnpoly2 rl=20 rw=2
.SUBCKT rnpoly2 MINUS PLUS rl=2 rw=2
RR0 PLUS MINUS 190*rl/(rw-6.2e-3) $[NS] $W=rw $L=rl
.ENDS
But the generated CDL out file (File->Export->CDL) is
XI1 net16 gnd! / rnpoly2 M=1
.ENDS
The auCdl setting is given below
cdfId->simInfo->auCdl = '( nil
dollarEqualParams nil
dollarParams nil
netlistProcedure ansCdlSubcktCall
instParameters (rl rw m)
componentName rnpoly
termOrder (PLUS MINUS)
propMapping (nil L rl W rw)
namePrefix "X"
modelName "rnpoly"
Details can be found below
The cdf file is attached for reference
Thank you in advance for your help
The CDF settings are
let( ( libId cellId cdfId )
    unless( cellId = ddGetObj( LIBRARY CELL )
        error( "Could not get cell %s." CELL )
    when( cdfId = cdfGetBaseCellCDF( cellId )
        cdfDeleteCDF( cdfId )
    cdfId  = cdfCreateBaseCellCDF( cellId )
    ;;; Parameters
    cdfCreateParam( cdfId
        ?name           "model"
        ?prompt         "Model name"
        ?defValue       "rnpoly"
        ?type           "string"
        ?display        "t"
        ?editable       "nil"
        ?parseAsCEL     "yes"
        ?name           "macro"
        ?prompt         "Hspice Model name"
        ?defValue       "iPar(\"model\")"
        ?type           "string"
        ?display        "nil"
        ?editable       "nil"
        ?parseAsCEL     "yes"
        ?name           "macroArgumentStyle"
        ?prompt         "macro arg style"
        ?defValue       "hspiceS"
        ?type           "string"
        ?display        "nil"
        ?parseAsCEL     "yes"
        ?name           "r"
        ?prompt         "Resistance"
        ?units          "resistance"
        ?defValue       "190"
        ?type           "string"
        ?editable       "cdfgData->entryMode->value == \"Resistance&Width\""
        ?callback       "preswl_1Si()"
        ?parseAsNumber  "yes"
        ?parseAsCEL     "yes"
        ?name           "tr"
        ?prompt         "Total resistance"
        ?units          "resistance"
        ?defValue       "190"
        ?type           "string"
        ?display        "deGetEditCellView()->cellViewType != \"maskLayout\""
        ?editable       "nil"
        ?parseAsCEL     "yes"
        ?name           "entryMode"
        ?prompt         "Entry Mode"
        ?defValue       "Length&Width"
        ?choices        '("Length&Width" "Resistance&Width")
        ?type           "cyclic"
        ?name           "rl"
        ?prompt         "Length"
        ?defValue       "2"
        ?type           "string"
        ?editable       "cdfgData->entryMode->value == \"Length&Width\""
        ?callback       "presr_1Si()"
        ?parseAsCEL     "yes"
        ?name           "rw"
        ?prompt         "Width"
        ?defValue       "2"
        ?type           "string"
        ?display        "artParameterInToolDisplay('w)"
        ?parseAsCEL     "yes"
        ?name           "m"
        ?prompt         "Multiplier"
        ?defValue       1
        ?type           "int"
        ?editable       "deGetEditCellView()->cellViewType != \"maskLayout\""
        ?callback       "presm_1Si()"
  • berndf
    berndf over 15 years ago
     I believe the issue is related to your propMapping.
    You do a "propMapping (nil L rl W rw)" in the auCdl simInfo, but
    in the parameter section you have defined "rl" and "rw".
    Bernd
  • Paulux
    Thanks Bernd.
    After I modify from "propMapping (nil L rl W rw)" to propMapping (nil)" and generate new auCdl netlist, the parameters are still missing.
    .ENDS
    Could you/anyone please suggest how to modify propMapping so that auCdl can generate "XI1 net16 gnd! / rnpoly2 M=1 rl=20 rw=2"?
    Thanks in advance for your help
  • skillUser
    skillUser over 15 years ago
    Hi Paulux,
    I think that you may want to look at the ansCdlPrintInstParams or ansCdlPrintInstProps functions in the documentation - set the auCdl netlist procedure to ansCdlHnlPrintInst and then you will be able to customize how the device is written to the netlist. Put any procedure definitions in your .simrc file, if you need to overwrite the default implementations.
    Hope this helps.
    Lawrence.
  • Paulux
     Hi Lawerence,
     Thank you very much for your reply.
    Could you/anyone give an example in.simrc such that the "rl=" "rw=" appear in the line "XI1 net16 gnd! / rnpoly2"
    .ENDS
    Also, the problem is more series in capacitor subcircuit because only capacitance equation is printed in the auCdl netlist as shown below!
    XI2 in1 gnd! / umim
    .SUBCKT umim MINUS PLUS
    CC0 PLUS MINUS 1.5e-4*cw*cl $[CA]
    .ENDS
    How could the above capacitor parameters in auCdl netlist be added as shown below
    XI2 net17 gnd! / umim cl=15 cw=15
    .SUBCKT umim MINUS PLUS  cl=10 cw=10
    CC1 PLUS MINUS 1.5e-4*cw*cl $[CA] $L=cl $W=cw
    .ENDS
    Thanks in advance for your help.
