  3. Update Layout after schematic modification
  • Views 21630
pitter
pitter over 15 years ago
 I changed schematic connection (in schematic editor)  while drawing layout. Layout editor does not seem to notice the changes and an error is reported (wrong connection - yellow cross on the connecting metal path - short marker).A had this issue before, and it is pretty likely that LVS will fail, although schematic is OK. How to make layout editor update after making changes in schematic editor and not to draw short marker?
IC613, PDK - AMS
 Kind Regards,
pitter.
    Hi pitter,
    Your question is a bit unclear, so let me take a guess. If using Layout XL (or VLS XL in IC61), then you would need to do Connectivity->Update Components and Nets (and potentially a "check" operation on the schematic if you've not done so already). This doesn't happen automatically (because it would be really annoying to have it change half way through doing the layout, if you wer e only half way through making the schematic changes...).
    I didn't quite undefrstand what the "error is reported (wrong connection)" meant - what is giving the error? If the Layout Editor has not noticed the changes, how is it giving an error? Confused...
  • habet
    habet over 14 years ago
     Hi Andrew
    I have a question about updating layout !!
    When i change nomber of fingers (nmos) in the schematic and i try to update de layout (connectivity ->update) the layout don't change !
    some one can help me
    Regards
    Not enough information to go on, and please do not post to an old thread (as outlined in the Forum Guidelines (the very top post in the forum).
