  3. which command can set the ADE environment swith view list...
  • Replies 13
  • Subscribers 136
  • Views 24851
which command can set the ADE environment swith view list and stop view list?
imagesensor123
imagesensor123 over 15 years ago
 hi,
   these days, i'm writing the ocean script and i have a problem to add the verilog-a to the swith view list, can you help me
     Zfeng,
    Why would typing something once in the CIW alter the default configuration? It will only change it for that session. If you add the statement to your .cdsinit file, it will set it up on each launch of virtuoso.
  • fabriceBG
    fabriceBG over 11 years ago
    Is anybody know what is the difference (if any) of these two approcah to set switch view list:
    1- envSetVal("spectre.envOpts" "switch View List" ....
    2 - asiSetEnvOptionVal(asiGetTool('spectre) "switchViewList" .......
    regards,
    Fabrice
    Hi Fabrice,
    Other than one expects a space-separated string and the other expects a list, it doesn't make much difference which you use.
    The main difference is that to use the asiSetEnvOptionVal, you have to call asiGetTool which will load all the relevant context files to initialize the spectre interface, whereas envSetVal doesn't require anything to be loaded. So it will be a bit quicker in the .cdsinit (and not load contexts that you may never need if you were just doing layout).
    So I'd use the envSetVal approach (it's more consistent with other settings to use this rather than an ADE-specific interface).
