  3. which command can set the ADE environment swith view list...
  • Replies 13
  • Subscribers 136
  • Views 24849
which command can set the ADE environment swith view list and stop view list?
imagesensor123
imagesensor123 over 15 years ago
 hi,
   these days, i'm writing the ocean script and i have a problem to add the verilog-a to the swith view list, can you help me
     envOption('switchViewList '("veriloga" "spectre" "cmos_sch" "cmos.sch" "schematic")
    You can also set 'stopViewList this way. Note that switchViewList would normally contain veriloga by default, but it's at the end usually.
  • berndf
    berndf over 15 years ago
    This is an environment variable and can be sent in the .cdsenv file
    like:
    spectre.envOpts    switchViewList    string    "spectre cmos.sch schematic veriloga"
    spectre.envOpts    stopViewList    string    "spectre symbol"
    or with skill
    envSetVal(
    t_tool[.Partition]
    t_varName
    s_varType
    g_newVal
    I don't know if this works embedded in your OCEAN script.
    Bernd
  • berndf
     An other way which would in my optinion be good for OCEAN
    could be the "asi" commands
    asiSetEnvOptionVal( asiGetCurrentSession( ) 'switchViewList '("spectre" "schematic" "veriloga") )
    Bernd
    Hi Bernd,
    Or you could use the envOption function (which is an OCEAN function) that I mentioned earlier (our replies crossed in the post) ;-)
  • imagesensor123
         thanks, i think you're right, but in my session the "verilog-a" is not included in the swith view list by default, how to change the default view list ?
    Regrads,
    zfeng
  • imagesensor123
     Hi Bernd,
        thanks for replying!
    zfeng
    Hi Zfeng,
    If the view is called "verilog-a" (with a dash) then it wouldn't be in the list. You could add an entry in your ~/.cdsenv file with the default you want - I can't check the exact syntax because I'm now not online - Bernd may have mentioned it earlier.
    Or you could just call envOption in your script, as I suggested.
  • imagesensor123
     i have added this line " envSetVal("asimenv.startup" "switchViewList" 'string "spectre cmos.sch schematic veriloga") " in my .cdsinit (in my work directory), but it seems that the default value doesn't be changed at all. I think the syntax is ok, did i put it in a wrong place? as somebody says, the cdsenv file will be overwriten by the.cdsinit, so i did not put this command in .cdsenv file. welcome to any reply,thanks
    zfeng
    Zfeng,
    This would have given a message in the CIW (assuming you've not filtered away the warnings):
    *WARNING* envSetVal: Can't set the value of variable 'switchViewList',
            in tool[.partition] 'asimenv.startup' - it has not been registered.
    That's because it's incorrect. The first argument to the envSetVal() should have been "spectre.envOpts" not "asimenv.startup". The switchViewList is simulator specific.
    Always a good idea to check any warnings you get...
  • imagesensor123
       yes, you're always rigth. i have changed the command and typed it in CIW, it worked well, but when i exit the cadence, and login again, the added "veriloga" disappeared again, so I think i did not change the default configure, so what do you think about this problem,
    zfeng
