  3. add an ivCellType property (value: graphic) in all the layout...
  • Replies 9
  • Views 16786
add an ivCellType property (value: graphic) in all the layout cellviews of a library
isazulkc
isazulkc over 15 years ago
Hi, I want to add an ivCellType: graphic to all my layout cellview. I know I can do it individually in each cellview, but it's too long. There is an efficient way to do it at a library level ? Thanks
  • Quek
    Quek over 15 years ago
    Hi isazulkc
    You can use the following skillscript. It will add "ivCellType" property with value "graphic" to all cells in a library. Please save it as "createprop.il" in the working directory and load it in ciw using:
    load "createprop.il"
    Execute it using:
    CCScreateProp("yourLibName")
    OR
    CCScreateProp("yourLibName" "ivCellType" "string" "macro")
    Diva does not check for ivCellType property at the library level.
    Best regards
    Quek
    procedure( CCScreateProp(myLib @optional (myProp "ivCellType")
        (propType "string") (value "graphic"))
       let( (libID bag)
          libID=ddGetObj(myLib)
          foreach( cell libID~>cells
              bag=dbOpenBag(cell "a")
              unless( dbFindProp(bag myProp)
                dbCreateProp(bag myProp propType value)
            printf("Property added for cell %s\n" cell~>name)
              ) ;unless
              dbSaveBag(bag)
              dbCloseBag(bag "a")
          ) ;foreach
       ) ;let
    ) ;procedure
    createprop.il
  • Quek
    Hi isazulkc
    It is not possible to add a library level "ivCellType" property. You can use the following skillscript to add "ivCellType=graphic" to all cells in a library. Please enter the following in ciw after loading the script:
    Best regards
    Quek
       let( (libID bag)
              ) ;unless
              dbSaveBag(bag)
              dbCloseBag(bag "a")
          ) ;foreach
       ) ;let
    ) ;procedure
    createprop.il
  • isazulkc
    isazulkc over 14 years ago
    Hi Quek, Thanks for the script, I just try it. It add the "ivCellType" property to the cell property, but for macrocell extraction I need to add this property to the layout cellviews properties. How can I modify this script to add ivCellType graphic in the Layout Cellview properties instead of the cell property. Thanks a lot! Isazulkc
  • Quek
    Quek over 14 years ago
    Hi isazulkc
    You can try this:
       let( (libID bag)
              ) ;unless
              dbSaveBag(bag)
              dbCloseBag(bag "a")
              cv=dbOpenCellViewByType(myLib cell~>name "layout" "" "a")
              evalstring(strcat("cv~>" myProp "=\"" value "\""))
              dbSave(cv)
              dbClose(cv)
         ) ;foreach
       ) ;let
    ) ;procedure
    Best regards
    Quek
  • isazulkc
    Hi Quek, There is some error when running as all the cell in the library don't have a layout view. I'm sure only a condition line in the script will solve the problem. However I don't have any knowledge in skill. Do you have some good reference to learn skill or do I need only to go through cadence reference and user guide? Thanks to tell me the condition line to add and some goods reference for skill. Best regards, Isazulkc
    Isazulkc,
    Change this bit:
              dbSave(cv)
              dbClose(cv)
    to:
              when(cv
                dbSet(cv value myProp)
                dbSave(cv)
                dbClose(cv)
    I also changed the evalstring bit to use dbSet which is cleaner than using run-time evaluation.
    Note that I didn't test any of this - it was just from visual inspection of the SKILL code.
    Regards
  • isazulkc
    Thanks, that works fine now :-). Could you advise some good references to get into and develop skill script.
    Best regards,
     Isazulkc
    Try the SKILL Language User Guide.
  • isazulkc
    Thanks !
    Isazulkc
