  3. How to change save state default setup?
  • Subscribers 133
  • Views 16427
archive over 15 years ago
I'd like to change the default configuration when saving state in ADE (L): I want to uncheck "Model Setup".
I can't find the corresponding environment variable to set (asimenv something I guess). I tried a CIW->Options->Save Defaults without success.
Anyone have a suggestion?
Seb
    Hi Seb,
    You can do the opposite, i.e. make the "Model Setup" unchecked during load of a state using this .cdsenv setting:
     asimenv.loadstate modelSetup  boolean nil
    That's the usual way to solve this problem.
    Nice! :o)
     Thanks you Andrew
